-   -   speedo not working (http://forums.pelicanparts.com/porsche-911-technical-forum/30319-speedo-not-working.html)
Bill Klima 05-16-2000 07:08 PM
speedo not working
just replaced shift couplings on 79 911 now the speedometer not working whats up with that??
H2O911 05-16-2000 07:40 PM
You might want to check for some loose/broken connections in that area (2 leads that connect to the speed sensor are under that cover plate if it is the same as a "77") just reconnect them and tape them up. It might get you going again.
s
