Headlight part number question - 73 2.4E
Does anyone know the part no. of the screw that attaches the lower edge of the headlight assembly to the tab on the front guard (fender)?
The lights are Euro H4's and are mounted by a lip at the top engaging a matching lip on the top of the guard and this screw on the bottom.
The tab is inside the headlight recess on the guard and I'm pretty sure has a threaded hole.
The PO of my 73 2.4E has used some self tapping screws which keep working loose. From memory, the correct screw has a plain cylindrical part of larger dia near the head and a threaded part of smaller dia on the other end.
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 09-09-2006, 08:56 PM
Early_S_Man's Avatar
Porsche Crest
M5 chrome-plated brass countersunk Phillipshead screw... 901.631.119.00
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-09-2006, 09:01 PM
thanks warren
a pelican search on that no. yeilded "Part Superceded to 90027006307", which is "H5 Trim Ring Screw, 911 (1987-89)"
do you think this will fit a 73?
Cheers, Ryan
Old 09-09-2006, 10:55 PM
