what size injectors?
What size in lbs. per hour are OEM 3.2 Carrera injectors? I'm running 30 lb. injectors in my 3.0 EFI conversion and I'm wondering if they are the correct size. Thanks
bump because I want some bigger ones, and also I believe the carrera ones are 27#
I lied to you man, they're 21#
jerry yours are 31 ?? you should upgrade mine are 30lbs as well and I was thinking about going bigger yet
What is your duty cycle now on the 30's @ WOT?
read this from Todd at proto, it's an old thread but real info regarding size and limits of carrera injectors
http://p076.ezboard.com/fprotomotivetechtalk.showMessage?topicID=10.topic |
| All times are GMT -8. The time now is 05:42 PM. |
