Eye of the Toiger
matty74's Avatar
Shifter housing 4spd to 5 spd
Hi there,
I'm going to a 5 speed 915 tranny from a 4 spd do I need a completely new shifter assembly or can I re-use the housing.
I'm going to purchase a wevo 915 set up so I'm not sure if the assembly can be re-used or not.
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 09-09-2006, 03:46 PM
Bird. It's the word...
Fishcop's Avatar
No, same shifter....
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 09-09-2006, 04:07 PM
Eye of the Toiger
matty74's Avatar
forgive me if this a dumb question but I can re-use the housing for a 5 spd?
Old 09-09-2006, 04:14 PM
Fishcop's Avatar
Yes, as I understand it, the shifter is the same unit for both the 4 and 5 speed 915. The reverse is still in the same place on the gearboxes - ergo the reverse lockout (which is the important part) will still do its job on the housing.
Pretty sure there's been other posts on this, a search should bring something up.
Fairly sure the parts you get woth the Wevo set up sorts any discrepancies out. Shoot Hayden Burvill (owner) an email - he's great bloke and will answer definitively for you.
John Forcier
Old 09-09-2006, 06:54 PM
I just installed a 915 shifter housing in my '72 4 speed which had the 901 style housing originally. Seems to work fine.
Jim
Old 09-09-2006, 07:42 PM
