WydRyd's Avatar
Question Removing left chain housing/cover?
Is there any easy way to remove the left chain housing/cover, or am I looking at an engine drop?
I need to remove it so I can tap the lowest point for an oil return, from the turbo.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-11-2006, 08:19 PM
Now in 993 land ...
aigel's Avatar
Not sure what's in front of it since you mention a turbo, but usually, on a n/a car, the muffler and the engine tin are all you need to remove to get there.
George
81 SC (sold)
Old 09-11-2006, 09:29 PM
WydRyd's Avatar
Well, the turbo isn't in front of it yet, it will be eventually.
If it's just the engine tin surround, then that's easy
Merv
'89 911 Turbo Cab
Old 09-11-2006, 10:32 PM
Now in 993 land ...
aigel's Avatar
Just to clarify, the muffler too, but that probably won't stay anyway.
Have fun!
George
81 SC (sold)
Old 09-11-2006, 10:56 PM
WydRyd's Avatar
That's correct. The whole exhaust, from the heads to muffler tip will be removed.
I take it I'd need to drain the oil before removing the chain cover, right?
Merv
'89 911 Turbo Cab
Old 09-11-2006, 10:58 PM
Now in 993 land ...
aigel's Avatar
Yes, there will be oil in the engine up to that level, especially if it has sat for a while and some of the oil had time to drain back from the oil tank.
Cheers, George
81 SC (sold)
Old 09-11-2006, 11:08 PM
Bird. It's the word...
Fishcop's Avatar
Merv, you can cheat a little and jack up the left side to run the oil to the right side - this can save you effort for a minor job...
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 09-11-2006, 11:17 PM
WydRyd's Avatar
He he, very clever John. I'll take that into consideration when I remove the chain cover! Thanks!
I plan to have a 3/4" barbed tube welded to the chain cover. Plenty big enough for a turbo oil drain
Merv
'89 911 Turbo Cab
Old 09-11-2006, 11:33 PM
