77' 911S gauge problem
Hey guys needs some imput.
every once and a while the 1st 2 gauges on my 77' 911S will fog up like crazy. It is a non-AC Targa and it is the fuel/oil level and the oil tank level/temp gauge that are the culprits. Is this something I should be concerned about or just let it go and be thankful I do not have larger problems.
thanks in advance,
Chris
Old 09-06-2006, 04:02 PM
cfarmer,
I have read that this happens to a lot of cars. Someone suggested drilling two small holes in the back of the gauge and using a hair dryer to air it out.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 09-06-2006, 05:22 PM
cfarmer,
I get the same situation with the oil temp/pressure gauge on my 75S, on occassion. Usually it's comes on an especially damp morning, or when my slightly damp car cover is in the trunk. I think it is typical of our cars as the trunk area isn't air tight, and the back of the gauges may not be either. The "fog" usually disappears after driving awhile. Like you said, if you're going to have a problem, this is one to have!
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-07-2006, 06:55 AM
Typical condition, don't let it bother you.
fog up like crazy
Mine is just once in a while, and just a little bit.
Old 09-07-2006, 07:05 AM
thanks to all you replied.
C
Old 09-11-2006, 07:27 PM
Zeke's Avatar
Turn the running lights on and crank up the brightness on the gauges. No? Then I'll go sit down.
Old 09-11-2006, 07:31 PM
