Banned
Fuel Injection Questions
While reinstalling the Fuel Injection I noticed 2 vacuum lines not hooked up. I looked in my Hanes and it showed nothing. What goes on these? Thanks Kerry
Old 09-11-2006, 07:03 AM
Scott R's Avatar
The one on the left is the drain for the CIS airbox, for the most part nothing goes there, I have seen a few with a drain hose that goes down and out the back. The one on the right is the cold start valve block, you should have a very large hose/metal line that goes to the AAR and AAV loop, I doubt the car will even start with that missing.
The silver looking metal line in this picture is the AAV/ARR/Decel loop.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-11-2006, 07:53 AM
Banned
Wellllll that is verrrrrrrrrry interesting. Mine has none of that stuff and it did start and run pretty well before I pulled it down to reseal some leaks. Looks like PO removed all the AAV stuff
Kerry
Old 09-11-2006, 08:02 AM
Scott R's Avatar
Kerry
I suppose it would be posible to block off the port at the CSV and run the system, you would however need to live in a very warm climate since you no longer have the AAR asist on startup.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-11-2006, 08:14 AM
19 years and 17k posts...
azasadny's Avatar
Kerry,
On my '74 911 with CIS, the CSV plug is a "blank" and is not used at all.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-11-2006, 10:47 AM
Scott R's Avatar
Originally posted by azasadny
Kerry,
Then I take that back, do you guys have an AAV and an AAR? Is it just plumbed in a different matter?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-11-2006, 10:54 AM
azasadny's Avatar
Scott,
My '74 does not have an AAV or AAR. I have a WUR, CSV, all of the other "usual suspects" in the CIS, but my '74 does not have these two components and I don't believe they came with the '74 CIS but the CIS was modified every year and more and more components added/ modified.
Art Zasadny
www.ford.com
Old 09-11-2006, 12:26 PM
