-   -   Flashers stopped working (http://forums.pelicanparts.com/porsche-911-technical-forum/30385-flashers-stopped-working.html)
Mike the mechanic 05-24-2000 03:10 PM
On my drive home from work today, my turn signals stopped working. My hazard lights work, no bulbs are burnt but when I flick the turn switch, nothing happens. Is there a separate relay for flashers? I can't check it out till tomorrow, it's raining hard outside.
Mike
Jens Wendorff 05-25-2000 04:34 AM
Should be the Relay. Its a combination for emergency and turn signals. Mine worked for the turns-not for the emergency.
On '76 onward cars, the relay is located just underneath the instruments. You get access from the luggage compartment.
Mike the mechanic 05-25-2000 03:50 PM
Thanks, although I finally checked it and it was a burnt fuse.
Mike
