Nitrogen in tires
Does anyone run nitrogen in their tires? Has anyone heard about this? I have been told by some experienced tire people that it is far better than using air. It's more stable and doesn't fluctuate at all with temperature. It even conditions the inside of the tire to fight cracking. Somehow it can even increase tread wear. Just curious if this is snake oil or the real deal. Apparently the Nascar guys are running it. For $5.00 bucks a wheel it's not a bad deal if it works.
Mike.
1972 911T, non-sunroof coupe.
Old 09-10-2006, 05:41 PM
jdm61's Avatar
I had nitrogen put in my Michelin Energy's on my 325i. All i can say is that I have put over 50,000 miles on them and i have at least another 30k to go......so they will actually do what they are rated for. Also, I have never had to put air in them myself. Only had them topped off when needed when I get the oil changed.....and that is every 12-13,000 or so. Not sure whether it is the tires, the nitrogen or both, but I have had good luck with the combo. In theory, you would avoid any oxidation issues inside the tire.
1985 M491 Carrera Slate Blue Metallic(fun car)
2001 BMW 325i (basic tranportation)
http://jmforge.com
Old 09-10-2006, 05:45 PM
Retired Member
Brian 162's Avatar
Unlike air from a compressor nitrogen has no moisture in it. I use it to pressure test A/C systems. In theory it should maintain consistent air pressure in tires. Costco I think has nitrogen.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 09-10-2006, 05:54 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
The only advantage to use nitrogen in tire is no corrosion will happen to the wheel because it is an inert gaz...!!!
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 09-10-2006, 06:04 PM
i'm just a cook
onlycafe's Avatar
how about helium to reduce unsprung weight?
Old 09-10-2006, 06:18 PM
no one should even answer that one
Old 09-10-2006, 06:34 PM
jeffgrant's Avatar
I also thought that it had different expansion properties than ambient air so it won't expand as much as you build heat into the tires... so your pressures stay more consistent when on the track.
Old 09-10-2006, 07:05 PM
anthony's Avatar
I think it's a "profit center" at tire shops. The air we breath is 78% nitrogen. If you put an water filter on your shop compressor you'll end up a higher percentage of nitrogen.
I recently heard about valve stem caps with o-rings. Supposedly they do a lot towards keeping the air in the tire.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 09-10-2006, 09:50 PM
Zeke's Avatar
Please read this thread for a lot of discussion on N.
Old 09-10-2006, 10:50 PM
Earthling
Brian Cameron's Avatar
Problem is, this will cause your tires to make a really high pitched squeal when cornering hard...
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 09-10-2006, 10:55 PM
anthony's Avatar
http://www.nitrogentiremachine.com/
Put "Nitrogen in Tires" with the simple touch of your finger and generate an "Average Profit Margin" of 1000% on each service!
GWR's revolutionary design automatically delivers consistent 99.99% or purer Nitrogen to the tire, the highest percentage in the industry. At only .35˘ to .45˘ per tire, that's less than $2 per vehicle! Not bad when you consider the average retail ticket for four tires is over $24. Yes, a 1000% mark-up with virtually no labor or parts, plus anyone on your staff can do the simple service.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 09-10-2006, 11:09 PM
Wer bremst verliert
JohnJL's Avatar
Toyo advocates it on their site. And search.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-11-2006, 03:41 AM
David's Avatar
There's nothing special about Nitrogen, the air we breath is about 79% nitrogen. The key is there's no moisture in compressed nitrogen. So yes it's better, whether it's worth it or not is up to the individual.
Old 09-11-2006, 05:00 AM
charleskieffner's Avatar
i would be afraid of nitrogen narcosis driving at lower altitudes!
Old 09-11-2006, 05:07 AM
Wider is Better
wholberg's Avatar
It's nothing but marketing...creating a market where one had not existed before to make more money. Dry compressed air would be the same, but it would not sound as fancy. Would you buy it if the slogan was:
Nitrogen, the Cool Collar for tires!!!
Disclaimer: This is a fictional allegory. Any resemblence to actual Cool Collars, living or dead, is unintended. No Cool Collars were harmed in the production of this message.
Wider is Better
Old 09-11-2006, 07:16 AM
jeffgrant's Avatar
I guess it's just easier to use Nitrogen to achieve the dryness as opposed to having to have a dry compressor.
Old 09-11-2006, 09:57 AM
Maybe I'll try it my truck to see what I think. It doesn't get a lot of use so the pressures vary.
Mike.
Old 09-11-2006, 10:00 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I am a mechanic on a 997 GT3 Cup car in the Grand Am Rolex series. We always use nitrogen in tires to reduce the amount of pressure rise due to increased temp. Our tires rise 10 to 12 psi even with Nitrogen. Using air would be a little more. I think Nitrogen is good because it is consistent (always dry). Air at different parts of the country would have different amounts of moisture in it and thus would be less predictable. For my personal race car, I use air (with a basic air separator) and my tires increase about 10 psi at the track. The local tire shop charges $2 per tire to fill with nitrogen. However, unless you purge (fill and empty the tires about 3 times) with nitrogen, the use of Nitrogen is a waste of money.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 09-11-2006, 05:26 PM
DUK DUK is offline
DUK's Avatar
The reason to use nitrogen isn't pressure increase it's the expansion of the gas, dry nitrogens expansion rate is less than dry "air" and far less than unfiltered and undried "air". We actually did some back to back runs at Talladega trying to see if the spring rate of the tire was affected by what was in it. The only conclusion was that nitrogen helped to keep the spring rate linearly progressive. The pressures were within a tenth of a pound on a ten lap run going from nitrogen to undried "air". As far as the corrosion issue, I have seen the plus' of nitrogen.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 09-11-2006, 05:40 PM
randywebb's Avatar
"isn't pressure increase it's the expansion of the gas"
PV = nRT
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-11-2006, 06:07 PM
