regular maintenance
Does someone have a list for service items after 60 000 miles for a 89 3.2 Carrera
What type of transmission fluid is better 75W90 or 80W90? is there a transmission oil filter? Does the differential have a different oil or does it use the transmission oil? |
Just off the top of my head this is what I would do:
Valve adjustment. Change your spark plugs, rotor and distributor cap. Check your plug wires and wire boots for cracks/deterioration. New air filter New fuel filter Check CV boots and bolts Change oil and filter Replace tranny fluid. There is no filter and the transmission and differential are one unit using the same fluid. Get a new DME relay and change out the old one. Keep the old one for a spare. Upgrade your lights by installing relays to take the load off the wires in the system. Check your fuses and replace the ones that look corroded or just old. |
Just curious...why replace the DME relay...??? My 3.2 is at 90000 and want to know if this apply to me as well...Thanks
Rick |
I will do it for sure...thanks Kurt V.
| All times are GMT -8. The time now is 05:44 PM. |
