Exhaust gasket
I put my cat back on, and I have an exhaust leak on the engine side of the cat. I had issues with getting the gaskets to stay in place. What can I use that is slightly sticky to hold the gasket in place long enough to get the cat in place?
82 911 SC
3.0, 915
Old 11-05-2010, 12:42 PM
Fleabit peanut monkey
Bob Kontak's Avatar
There are threads to search on this topic. Some good discussion. Double gaskets, etc.
The one I went away with was to get the cheap $5 muffler mender in a tube and put some on both sides of the gasket. Helps stick the gasket on and can seal small leaks.
Old 11-05-2010, 01:32 PM
The sad thing is that with the test pipe its perfect! I'll get some muffler mender, thanks.
82 911 SC
3.0, 915
Old 11-05-2010, 02:14 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Who needs a gasket? Blew mine out about 6 months ago...sounds so good I havent the heart to replace it.
I've used small dabs of vaseline before. Burns off when you're done.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 11-05-2010, 03:16 PM
Bob Kontak's Avatar
My original cat leaks too. Fabspeed SS Euro Pre Muffler (um - fancy test pipe) no issues.
Old 11-05-2010, 03:20 PM
