Heck why not, more knowledge is better for all of us.
Just curious how you will connect the +12v connections, what brand did you buy? Was it the guys from NY? I almost bought it but wanted a brand others here tried and tested for measure. |
without factory electric locks as a stock item in 1977 I installed Porsche electric door solenoids and the arm connecting to the door lock. I then went aftermarket for the relay pack and hooked it up to my Viper alarm beeper. I also installed up-graded window regulators, etc.
So which +12v fuses did you use?
i use an 8 circuit breaker panel mounted next to battery. others will tap into battery directly or tap into trunk fuse panel. http://forums.pelicanparts.com/uploa...1196156148.jpg |
Hmm. very interesting. Do you have pic of your set up yet?
Hope that helps, Bob |
Glad you replied, So just to verify, when you said #11 relay, you mean #8 hazard light indicator relay in panel section 1, right? |
The kit is from this guy in Seattle that has a bunch of power door lock kits on ebay. The reason I chose his is because he lists the actuators as "heavy duty". In my research on ebay I found actuators ranging in force from ~2.5kg - ~5.0kg. He didn't list the exact force these actuators apply, but I'm keeping my fingers crossed they'll be enough. I'll start a thread once I get the kit and have some time to do the install. Wish me luck! Jon |
Success!
Thank you Magic930 & Rcaradimos for your detailed installation. Here is my experience and verification of some issues: The Black Widow BW854, does come with some poor installation instructions for our P-Cars but tech support is great. *Basic Features - 8 wires in total: 3 to Ground Connection= Black, Violet & Violet/Black 2 to Power Source = Red & Yellow 2 to Power Lock Control = Blue & Green 1 to Parking Lights = White via Diodes Valet Button is needed for Programing and the LED is helpfull to see if programing was accepted by the module. I placed my LED where the interior cab temperature sensor would have been. *Remote Transmitter Layout - is definitely not marked properly, the Unlock is Button 2 and not the Trunk Button (actually #3) as stated in the manual. This is very important for proper programming of the module. *Valet Mode - To turn off or "override" valet mode you must hold the switch for over 5 (5-10 per tech support at BW) seconds and not 3 seconds as stated in the manual. This is the only way to turn off the LED Light when in Valet Mode. *Diodes - Radio Shack was out of stock and did not know when they will get some so I went to my local ham radio/electronics store and purchased some 3 amp diodes. The tech stated it is more than I will ever need. He said 1 amp would do just fine but to be safe he sold me 2 3amp diodes. I used the blue crimp and folded to double the thickness of the white (parking light control) wire to fit properly. Remember the silver marked end toward the fuse terminals (Panel 2 Fuse 5 & 6). I used Rcaradimos method of connecting the module's red (constant +12v) wire to the Clock Fuse terminal ('85's Panel 1 Fuse 1) and the yellow (switched, ignition monitor) wire to the Windshield Washer terminal (Panel 1 Fuse 7 jumper, the terminal right between Fuse 7 & 8 as described by Rcaradimos). I also programmed the module not to auto lock when ignition is turned on. The range is pretty poor, 10 to 20 feet but it's OK as long as I do not have to put my key in the handle and stop scratching the paint is all I wanted anyways. Lights and LED works perfectly. Hope this helps someone. I had difficult time because the buttons were not marked properly but once figured out and spoke to tech line. It was a snap. I am very happy with the results. Thanks again fellas, |
Antena Boost Cheap
Update:
I got fed up with the low range of the Black Widows antenna so I did an experiment: My baby has two antennas one on the windshield and the power antenna that my radio is hooked up to. I was cleaning up the wires underneath the dash and saw the windshield antena just hanging there. I pulled it through the fire wall and spliced it to the Black Widow's antena. Not expecting much but SUCCESS! I now have a 30-40 yard radius range. Very Happy and no need to buy an external booster. So if you guys have both antenna's connect it and it will increase your range. SmileWavy |
I put a Y connector in fender antenna wire to plug in the remote alarm pager transmitter. Big difference if antenna is up most of the way.
I have to disconnect the remote dook lock wire to the parking lights or put a fuse in line. |
Whoa:eek: fuse? You used the diodes right? My electronic store stated 1 amp is good enough but 3 amps is a guarantee. over, |
bell said crooks break the lens and short the bulb socket so the alarm brain crashes. So he said a fuse prevents that from happening.
So do you put the fuse on the LED line or the parking light circuit and if so what size (amp)? TIA |
I haven't done it yet. I guess a 3 amp fuse should allow enough current to work the parking lights without blowing?
Oh I see,
When you do do it, could post a pic for us? TIA |
I just finished the hook up today. I did the simple, simple hook up. No diodes, no horn, no flashing lights, nothing. Just lock and unlock. I also got it programmed so it doesn't lock when the ignition is turned on. The range for me as is is just fine for now. Thanks a lot for the thread Magic930 and everyone's comments. Couldn't have done it with out ya!
PS - I got the BW 854 from Amazon for ~42 shipped. |
I recently installed mine, too. The harness has little tabs on the back – push the tab in and the wire slips right out. I removed all wires not necessary for simple lock and unlock. This makes a very clean install possible.
The system works great – I get about 40 foot range. Thanks for all the help – couldn’t have done this without it Paul http://forums.pelicanparts.com/uploa...1223678843.jpg http://forums.pelicanparts.com/uploa...1223678862.jpg |
EDIT: Made a few changes.
Bringing this one back from the dead. After buying the BW854 unit 3 years ago, I decided to install it this weekend, but I can't get it to work. I followed the posts above, but I must have done something wrong. I was looking for a simple install with no horn, dome lights, valet switch, remote LED or aux functions Can you guys check my wiring below? I replaced the remote batteries with new ones. The red LED light on the does work when a button is pressed. When I start the car, the door locks "lock". When I turn it off, the door locks "unlock". 3 to Ground Connection= Black, Violet & Violet with black tracer 2 to Power Source = Red to constant power & Yellow to switched power (per magic930's picture) 2 to Power Lock Control = Blue with black tracer to brown with green tracer & Green w/ black tracer to brown with blue tracer. 1 to Parking Lights = White via Diodes Any ideas? |
| All times are GMT -8. The time now is 03:19 AM. |
