choosing an exhaust
Fellow Pelicanites,
I've got a 76 911S Targa sitting in my garage that I want to use as a daily driver (and eventually take to the track). I'm looking into getting exhaust and headers for a little more power. Any suggestions out there, please.
Old 02-01-2007, 10:15 PM
thinkfloyd14's Avatar
Send a message via AIM to thinkfloyd14
Depends on your price range.
For about 1500 dollars you could achieve probably the most popular set up used on these boards and by me. I've never heard of anyone being disappointed with the sound and performance of an M&K Mufller matched with SSI heat exchangers.
heres the links to the two
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_EXHmuf_pg3.htm
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_EXHpip_pg2.htm#item5
if your budget is running low, then try the SSI's which will guarantee you power and try modding your stock muffler to be a bit more sportier which will cost you less money.
DIY early sport muffler
sammy
1976 911S
http://imgur.com/aSW9DtX
Old 02-01-2007, 11:23 PM
IROC's Avatar
If you're in a location that doesn't require heat, you can just get a set of headers and whatever muffler you like. This allows you to remove alot of crap from the rear of the car and reduce the weight. Weight reduction is probably just as imprortant as the small hp increase you'd see from the exhaust changes.
I had headers on the 2.7 that was in my 76. The headers (George's) weighed about 12 or 13 lbs (IIRC) and the Supertrapps I used with them only weighed 6 lbs each. The factory exhaust weighed around 50 lbs (again, IIRC). I also removed the heater blower motor and all the associated heater stuff. Saved alot of weight.
And ti sounded glorious. :>)
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-02-2007, 04:50 AM
81 911 SC's Avatar
I've got a set of SSI's and a GHL 2in/2out on my 81. If you go with a 2in/2out be prepared for some resonance back in the cabin typically between 2-3k rpm.
- Tyler
1988 911 Carrera Grand Prix White/Black
2015 Cayenne Diesel Black/ Luxor Beige/Black
Old 02-02-2007, 05:40 AM
ssis if you want heat and for them to last forever.. then a nice 2in 1 out muffler is the way to go.. couple of brands are
Bursch
Monty
triad
ansa
M&K
GHL
And modified Flowmasters
Lots of info out there and that is as far as I can go as I am biased
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-02-2007, 08:11 AM
81 911 SC's Avatar
you biased.... no way
- Tyler
Old 02-02-2007, 01:05 PM
scarceller's Avatar
I have SSIs with M&K 2in2out this setup came with my 84 3.2L and the 2in2out pipe was LOUD! to loud for my taste but after speaking to M&K they said just cap one of the outputs with a cap, they actually sell caps for this purpose. So I guess if I bought it myself I would go with M&K 2in1out for street use. However, if you will street and track the car I would go with M&K 2in2out and just cap one side for street use. This way you can remove the cap on the track and get the best of both worlds.
Another thing I learned from M&K is that they produced early version of these pipes and then over the past few years a newer version, here's the diffrence:
The early version has no packing material and are louder, I have this pipe but it sounds great on the street with one side capped.
The new versions have packing material and are not as loud.
If I had a street\track car I would preffer the earlier version, but they are hard to find. You may wish to contact M&K about them. Here's the website http://www.mkexhaust.com/
Good luck
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-02-2007, 01:38 PM
Sound is a very subjective thing, but I will tell you this: the build quality and weight of the M&K mufflers are second to none.
Old 02-02-2007, 03:25 PM
Thank you all for your replies!
Old 02-04-2007, 01:55 AM
