jmshepard's Avatar
PMO Fuel Regulator connection help
I need some help with a PMO Fuel Regulator. The device was delivered without a tech sheet.
The outlets for the carb connections seem obvious.
I cannot determine which connections are for the fuel tank inlet and fuel tank return.
Neither the PMO site or in the PP archives have the answer.
Thanks,
Jim S.
Old 02-01-2007, 06:23 PM
It's been awhile, but I recall that the lower is the fuel inlet and the upper is the return line. Functionally, the regulator controls pressure at the return, so you can see how this makes sense. I'll double check my paperwork tonight after work.
Old 02-01-2007, 06:37 PM
jmshepard's Avatar
Thanks Jon
I say we take off, and nuke the site from orbit. It's the only way to be sure.
2009 Cayman
Old 02-01-2007, 06:47 PM
jhora's Avatar
Jim,
Here is a copy of the PMO doc on this.
John
Old 02-01-2007, 07:05 PM
jmshepard's Avatar
John,
Many thanks.
Jim S.
2009 Cayman
Old 02-01-2007, 07:15 PM
HEY, I need one of this fast!!
Can't find it here, please help.......thx
Old 02-02-2007, 09:06 PM
Pelican doesn't list the regulator, but since they sell PMOs I'm sure they can get it for you. An aftermarket regulator (like a Holley) will work, but it's hard to find one that allows for a return line so you would need to block off the return.
Old 02-03-2007, 09:23 AM
randywebb's Avatar
you can get it direct from Richard Parr (Mr. PMO) -- IIRC, he has a web site.
2 choices - pretty billet one as shown for $80
or functional equivalent w reduced bling effect for $40
- maybe some price increase in last few years
it mounts to the body via the tab on the bottom using sheet metal screws.
BMW makes a good fuel line to use - IIRC, it is 8 mm
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-03-2007, 11:23 AM
Pelican sells PMO parts. I made a small issue to pelican HQ yesterday that their PMO parts cat makes locating and defining PMO parts a bit difficult.. although i may not be as smart as i look.
PMO return reg is good stuff.
Aftermarket Mallory fuel return regs are real nice also. If you go Holley you should go with the higher end dual diaphragm that's acceptable to to exotic fuels as our gas station fuels have become a bit more dangerous when using the $20 Holley reg.
Actually.. i have two almost brand new $20 Holly dead head regs w/rebuild kits that i'll use for someting else.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-03-2007, 02:39 PM
randywebb's Avatar
"although i may not be as smart as i look."
- OK - let's see a pic, Ron...
Old 02-03-2007, 04:44 PM
cfries's Avatar
jmshepard,
you have a pm
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 02-03-2007, 05:40 PM
19 years and 17k posts...
azasadny's Avatar
I bought my fuel pressure regulator from Pierce Manifolds only because I was ordering other parts from them for the CIS-Weber conversion project late last fall. My fuel pressure regulator isn't as pretty as the PMO model and doesn't have the gauge on it. Works fine, though!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-03-2007, 07:05 PM
i'm the dumb looking one hanging w/a tour group last Sept in Peru at 14k ft..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-03-2007, 08:05 PM
Ronin LB
U have a PM.
Old 02-03-2007, 08:20 PM
Originally posted by Charles Lee
Ronin LB
U have a PM.
i did an edit on my post.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-03-2007, 09:14 PM
randywebb's Avatar
dumb on the right
dumb on the left
or dumb in the middle?
narrow it down to the nearest dozen for us...
Old 02-03-2007, 09:35 PM
