Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
78SC ROW -Oil Level needle raises on hard accel & hard braking (no pics this thread)
Hi All,
[quick note to thank everyone again for all the great help/assistance with my AAV valve, and the AAR regulator (and mixture) problems...]
1. Oil Level Sender was replaced in Feb and is known good.
2. I suspect the guage to be good as well.
Before you say "trust the stick only" -- becasue I do really only trust the dipstick, I just have this question:
Why would the needle RAISE on hard accel and hard braking only?
During normal driving it remains constant at a known good level.
Another vaccum leak someplace maybe?
It's strange. I know, fun one -- thanks again for the help guys!
-Tom
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 09-14-2006, 05:02 PM
Oh Haha's Avatar
Hmmmm..... I'm bumping this one for you 'cause I don't know.
Pacific Blue
Wayne
Old 09-14-2006, 06:19 PM
DW SD's Avatar
I doubt both conditions actually have to do with the oil level raising.
Keep in mind, acceleration and deceleration forces could be acting on the assembly itself. The assembly is in the front of the tank, but the arm curves towards the rear of the tank.
So......
Maybe acceleration acts on the oil (oil moves to the rear) to raise the sender float and de-celeration (braking) acts on the sender float assembly itself to move the arm as if it were floating higher.
OR Vice versa?
OR magic?
1971 RSR - interpretation
Old 09-14-2006, 07:00 PM
acapella8's Avatar
Could a sender that was installed incorrectly cause such behavior? Again, with normal driving it's fine. Only on accel and hard break does it surge up.
[GruppeB # 978]
Old 09-14-2006, 07:27 PM
gpshephe's Avatar
What does RoW mean?
Old 09-14-2006, 07:52 PM
Send a message via AIM to fintstone
Originally posted by gpshephe
What does RoW mean?
Mine does the same on hard acceleration, hard braking or unlevel ground. I believe it is normal.
RoW=rest of world....not the US model. That is why you are only supposed to trust the gauge when the conditions are the same as using a dipstick. Stopped, warmed up, at idle, on level ground.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-14-2006, 08:22 PM
jdm61's Avatar
In my car, if you are about to the point where the needle is normally at the halfway point, then it will swing quite a bit when you slosh the oil around in the tank by accelarating or braking. I can see itmove when I am going uphillor downhill unless it is showing all the way full at operating temp..
1985 M491 Carrera Slate Blue Metallic(fun car)
2001 BMW 325i (basic tranportation)
http://jmforge.com
Old 09-14-2006, 08:47 PM
Oh Haha's Avatar
Mine goes down on acceleration, as the pump draws oil from the tank. Most times I have noticed the nedle is at about halfway during normal sustained speed driving. Heck, it goes into the red sometimes. I don;t sweat it, though. I know the level is good as checked by the stick.
Pacific Blue
Wayne
Old 09-15-2006, 03:41 AM
acapella8's Avatar
So I am probably correct to guess that this is normal behavior?
[GruppeB # 978]
Old 09-15-2006, 06:09 AM
IMHO, yes. All the sender is, is a float on an arm that turns a potentiometer. It could not be otherwise.
Old 09-15-2006, 11:45 PM
