-   -   Source for coil wire terminals for '84 Carrera (http://forums.pelicanparts.com/porsche-911-technical-forum/304627-source-coil-wire-terminals-84-carrera.html)
CliffBrown 09-15-2006 07:29 PM
Update: Parts located, thanks.
I'm on a search for a coil wire terminal end to replace the one going to the dizzy.
Anyone know the nomenclature for the type of dizzy cap terminals used on the Carrera. I see the use of HEI type caps in the local parts house.
All I'm trying to do is replace the terminal end for the coil wire at the dizzy. The earlier coil wires are not the same size.
If I knew the proper terms for the terminals ends I should be able to buy the part at the local auto parts store on a Saturday.
I'd like to get the car back on the road tomorrow.
Jeff Alton 09-15-2006 07:49 PM
Kingsborne should have them.
Cheers
CliffBrown 09-15-2006 08:17 PM
Jeff
I think you got it exactly, thanks.
I found what looks like the correct terminal on their web site but I couldn't find any prices or how to order.
I'll give them a call on Monday.
Early_S_Man 09-16-2006 01:27 AM
Pelican has them:
WIRE END-DISTRIBUTOR
- This is a special-order, non-returnable, part
(availability and shipping charges may vary).
OEM-92860255701 $20.48
CliffBrown 09-16-2006 08:05 AM
Warren
Thanks, I should have checked a lot closer here first. Wayne is really adding to the list of available parts.
