Neatrix Install Question
How much force should I expect to apply when installilng Neatrix bushings. Is it customary to use a hammer with a wooden block in between? The OD is generously greased. Thanks.
Use long bolts to press it in with the t-bar cover plate. Work around slowly, and it'll pop right in. I used silicon spray on the outside of the bushing, and inside the seat.
| All times are GMT -8. The time now is 04:19 PM. |
