Smart quod bastardus
fredmeister's Avatar
correct spark plugs for 79 930 turbo
what are the proper Bosch and Champion spark plugs to use in a 79 930 turbo?
I have about 12 plugs from my 911SC that are Champion and Bosch but don;t know if they are safe to use in the 79 930 turbo I just purchased. Are the heat ranges ok to use in the turbo?
I want to perform a compresison check and figured on changing plugs while in there.
Old 09-23-2006, 12:21 PM
magic930's Avatar
Bosch heat range is 3 to 4, NGK 6 to 7.
I have used the following in my engine: W3DPO, WR4DP0, W4CS
Old 09-23-2006, 03:43 PM
beepbeep's Avatar
No. 930 requires different heat range. Use NGK B8EGV.
Thank you for your time,
Old 09-23-2006, 06:24 PM
