WUR Leaking 82 SC
The engine has developed an idle problem (it won't idle) and I went to check things out. There don't seem to be any vacuum leaks. What I did find is a slight fuel seepage around the area on the WUR that the fuel fittings screw in to. The fittings are tight so where is the leakage from? Can this be fixed or is a new WUR in order? Needless to say, no more driving until this is sorted out. After the leak is fixed, I'll look further into the idle issue.
Chris
Old 09-17-2006, 06:02 AM
Somatic Negative Optimist
Gunter's Avatar
Try new seals on one of the fittings.
The other one: Take the cap-nut off and inspect the convex part on the nipple for nicks or debris.
Idle problem could be for a variety of reasons: Vacuum leaks, mixture, AAR, AAV, Decel.Valve...........................
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-17-2006, 07:41 AM
