What's Waldo? help identifying parts
Pulled the webbers off of the 3.2 in the 72 project car I bought. I had a few questions about identifying parts and what to upgrade as I go through this.
In the picture, I'm assuming the yellow arrow is a canister type fuel filter? The fuel pump - white arrow was bolted to the left carb to manifold mount and was a pain to remove. Is this the best location? The pressure regulator - below the blue arrow was not mounted to anything, how should this be secured? What is the blue arrow going to - a thin tank on the rear wall, is this a charcoal canister for vapors? The red arrow is a line mounted to each manifold - is this a fuel return???????? These braided lines look ok but are probably 20 years old, should they be replaced and with what? http://forums.pelicanparts.com/uploa...1158587615.jpg |
HI your yellow arrow is to a fuel filter for a MFI engine.
the blue arrow is poss to a air tank for vack' on a sporto , without a better photo. the red arrow could poss be for the vac' take off for the brake servo. (as it is a 3.2 engine) the fuel pump is usually under the car near the L/H torsion bar tube. regards mike |
The yellow arrow is pointing to a MFI fuel filter ($$) but it certainly is not the right one to be using with a lower pressure carb pump mounted in the engine compartment. Definitely relocate that pump forward, probably near the tank. Your other guesses are probably correct to the lines and functions etc.
I have to wonder why anybody would swap a DME based 3.2 motor to carbs and then stick it in a formerly MFI 911. Quite the morphidite configuration you have there. Hopefully you did not pay too much for it. Good luck! YMMV |
It is a sporto car currently, the air tank makes sense. The car is a blend of many different parts through the years. Started life as a 72 911T sportomatic. Has had numerous SC and Carrera "upgrades" over the years. The engine came from a wrecked 84 but was converted using weber 46 IDA's.
Intent is to get it running and make it more of a track machine since originality is long gone. Any more thoughts/advice appreciated. Thanks, |
| All times are GMT -8. The time now is 05:49 PM. |
