-   -   What to do with my SC Badge (http://forums.pelicanparts.com/porsche-911-technical-forum/305127-what-do-my-sc-badge.html)
Gordo2 09-18-2006 08:51 PM
I have a tail on my '83 and it doesn't look right to me to mount it below the tail.
http://forums.pelicanparts.com/uploa...1158637724.jpg
Looking for suggestions on what to do with the badge. I'm considering polishing it and mounting it to my glove box door but it doesn't have long enough studs to extend all the way through the door to bolt/hold it in place. Wonder if I could tack weld a couple of longer bolts to the badge to let me firmly mount it.
Appreciate suggestions/opinions related to mounting it somewhere on the car.
Thanks, Gordo
jwetering 09-18-2006 09:36 PM
Well, you could misplace it like I did mine and then you don't have to worry about it. :rolleyes:
Or...you could grind the posts off and use double sided tape to attach it to any surface you like, including the glove box door.
Your call either way. SmileWavy
aigel 09-18-2006 11:21 PM
Throw in into the shelf in the garage until you sell the car and include it in the parts bin. That's wat I did. I deleted it from the non tail decklid for a cleaner look. My 993 is also a badge delete - it's not that you have to point out what car you drive. And that also answers what I think about the glove box idea.
G
umfan866 09-18-2006 11:34 PM
I don't know if you have the original decklid too, but keep that in case the next buyer doesn't like tails.
1911Guy 09-19-2006 12:05 AM
I had the same question. Decided to keep it off of the car. Looks cleaner in my opinion. Good luck
livi 09-19-2006 12:54 AM
Looks better without the badge.
And with a little luck people will mistake it for a Carrera... ;)
Rick V 09-19-2006 01:53 AM
When I installed a duck on my 82 I left the badge on the origional lid, the last time I checked it was still there.
wholberg 09-19-2006 05:40 AM
I think the glove box door will look cool, but I second the double-sided tape idea. That way, you can remove it if you don't like it. And if you someday want to put it back on the deck lid, adhesive works there too.
Hetmann 09-19-2006 07:38 AM
SC badge
Here's an idea...
http://forums.pelicanparts.com/uploa...1158676733.jpg
quattrorunner 09-19-2006 09:06 AM
Are you kidding?
you kust wanted to show off that exhaust!
Eric-325I 09-19-2006 09:26 AM
http://www.pelicanparts.com/support/smileys/spankA.gif
Shame on you... ;)
Mine is on the rear lid just under my Carrera style tail... Left it there as I didn't want anyone mistaking my SC for one of those 3.2s :D
Seriously though, when I update my body with fiberglass I will not put it back on... Weighs too much http://www.pelicanparts.com/support/smileys/wat6.gif
k9handler 09-19-2006 12:50 PM
Re: SC badge
Originally posted by Hetmann
Here's an idea...
Nice! :D
RFR 09-19-2006 12:53 PM
you could sell it to me.
Gordo2 09-19-2006 01:32 PM
Good Recommendations
Appreciate the recommendations.
Good thought on keeping it for re-install on the original lid. I forget that I have the original lid in storage and like the idea that at some point I may give it a temporary swap out for a change of pace (I will never sell my car though).
Another great idea on the 2 sided tape. Probably going to go that way w/the glove box, will post follow up when done. I like the fact that it won't ruin the glove box cover if I decide to remove.
Yes, self gratuitious pic of my home made exhaust... Besides, that's the main view Carrera owners see ;)
No question though, Hetmann is on top of it. Sweet ride and nice touch. Would love to do it but hate the idea of chopping the original badge. Are the badges hard to come by?
Thanks, Gordo
Hetmann 09-20-2006 12:49 PM
I chopped and polished a badge I found on ebay. They are not that hard to find. My original is sitting in on the shelf, probably to never be used again.
Ferrariguyma 09-20-2006 01:12 PM
Jerry
Can I ask for closer pics of your badge? How did you attach it? Is it mounted on something then mounted to grill or just free float attached to grill.
Andrew
kwm 09-20-2006 01:32 PM
Very Sweet SC Jerry I have never seen that car on here before, I PMed you if you dont mind.
onlycafe 09-20-2006 01:38 PM
"badges ? badges. we don't need no steenking badges."
schoward 09-20-2006 01:45 PM
leave it off and keep it handy for a future use/reinstall/future owner
dont care for it on glove box either...looks a little gaudy in my opinion
You could put it on a gold chain and wear it around your neck :D :D :D
tdatk 09-20-2006 03:59 PM
I posted this awhile ago....http://forums.pelicanparts.com/uploa...1158793137.jpg
Jadams1 09-20-2006 04:02 PM
http://forums.pelicanparts.com/uploa...1158793331.jpg
Hetmann 09-20-2006 05:54 PM
How I did my badge
I cut off the 911 part of the logo and sanded/polished the edge. I then sanded/polished the front. I took a scrap of aluminum and made it slightly larger than my badge to make a backer plate. I drilled three holes in the plate so the existing studs on the back could go through. I ran a little die down the studs to thread them and found some little aluminum offsets at my local hardware store to extend their length. The badge is fastened to my car with some big washers and nuts.
porsche930dude 09-20-2006 05:57 PM
id like to get a badge for mine but i dont care for the 911sc badge. Is there an aftermarket badge or even a stock one one that spells out Super Carrera?
