1988 930 turbo 2 fuel pumps location???? does anyone know?
Navin Johnson
in the front on the crossmember
in the rear up by the torsion tube drivers side
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
U need to remove the metal plate....
up front in order to get access to the pump....
1987 930 -Guards Red 2001 740I sport Blk 2011 F-150 supercrew Blk 2014 X3 2.8 white "What goes around comes around..." |
Are both pumps under that plate?
whewre is the torsion tube?
Front pump under the plate...second pump is under the car towards the left rear facing forward ..it is up just before the wheel well.
Just a suggestion...and a plug for wayne...get his book on a 101 porsche projects....it will give you alot of info..
