Wheel question
I currently have 8s on the rear. If I went to 9s would I then need to have the car set up differently or is it just "plug and play?" What about putting spacers in the rear? Would this accomplish the same thing (better look and handling)? Once again, would I need to set the car up differently with spacers?
Old 09-19-2006, 07:51 AM
Might help to know what car/year you are talking about as well as wheel diameter.
Tony G
2000 Boxster S
Old 09-19-2006, 08:41 AM
MBruns for President
JeremyD's Avatar
assuming 16 x 8 fuchs to 16 x 9 fuchs - no, would not make much difference.
Old 09-19-2006, 08:43 AM
The car is a 1989 3.2 Carrera. with 16x7 and 16x8
Old 09-19-2006, 08:52 AM
JeremyD's Avatar
So, your finished project would have 16 x 7's in the front and 16 x 9's in the rear (you can not move your 8's to the front unless you have 951 8's, btw)
Why bother, unless you are getting into race tires, the 8's would be sufficient for 245/45 tires.
Old 09-19-2006, 08:56 AM
911 in SC's Avatar
But if you do, please let me know if you decide to sell the 16x8s! I really want a pair...
Mike
Mike
'84 Grand Prix White RoW Carrera
Old 09-19-2006, 09:07 AM
I figured they would fill the wheel well better. Should I just use spacers?
Old 09-19-2006, 11:08 AM
GeorgeM's Avatar
If you want to fill, spacers are the way to go. I have H&Rs, the kind that come with longer studs that you'll need to press in (DRS series).
I can't remember the width, I'll have to measure them. I'm running 225s, so if you have 245s, you'll need to consider the extra rubber in your choice of widths so that they don't rub.
They shouldn't cost you much more than ~$150 for the pair with studs included.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 09-19-2006, 11:25 AM
9s should plug and play.
Many threads on spacers for your plans. In short, 911 8s with 245/45 can be pushed out max with 21mm spacers. You'll need 65-67mm studs. Search RoyB's post.
The spacers with push the 8s out more than actually 9s.
More negative camber will help avoid rub. I have -2.4 in the rears.
Buy the 928 21mm spacers from our host and 10 new studs... I know since I just did all this...
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 09-20-2006, 10:25 PM
Thanks everyone!
Old 09-21-2006, 05:57 AM
