My 73.5T charging light is on and I checked the voltage at the battery's and it only shows 12.2 volts even when I raise the rpm's, at the regulator the black wire ( I think the feed ) from the alt reads 1.5 volts also the blue wire (output?) so what does this mean ,
Ron 73.5 T 74 R90/6 (Tupelo Honey) 86 Carrera (Plan B) 1987 BMW K100RS Motorsport |
Not enough information to make a diagnosis yet. All we know is there is insufficient voltage reaching the battery.
Please do a search for information on this, there are a number of good descriptions (better than I could write) of a variety of tests that will narrow down the cause. One final thought, if you really have only 1.5 volts on the black wire at the connector to the voltage regulator, then I think your problem is in the alternator. Jerry M '78 SC Last edited by jmohn; 09-22-2006 at 09:44 AM.. |
I asked a garage ( friend) today and he said to ground the field side on the voltage regulator (the black wire) and if the alt is good you will here it pull the motor down and it will charge like crazy! so I just did that and....no change
Good luck, be careful, know what you're doing, Jerry M '78 SC |
Jerry ~ Thank you for the info , I tried it this morning and the battery voltage went up to 15.1 and the light on the dash went out so it looks like my voltage regulator is bad . Thanks again
Jerry , I may have “fixed” the voltage regulator ……I took the cover off it and it looked like a relay ( contact points) to me so I burnished the contacts and voila it charges!
You're quite right, part of it is a form of relay. If there's nothing else wrong with it (and apparently there isn't) cleaning the points is often all that's needed. Those points "make" and "break" constantly to contol the excitation of the alternator so there was (years of) built up corrosion on them. You probably already realize this, but be careful not to change the relative position of the points as they control the rate of charge.
Congratulations, Jerry M '78 SC |
