Eye of the Toiger
Can I use manifolds 35/46mm on 40mm webers?
what is the performance impact? Matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Eye of the Toiger
bump
You betcha,...
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Super Moderator
THey will fit.
However I've not measured the performance impact. Certainly you'd get some turbulence transitioning from the carbs to the manifolds, I imagine this would manifest itself primarily under high RPMs. You'd essentially have a "stall zone" in the air flow...
Works fine, and helps contain reversion when using race-type cams.
Super Moderator
Never thought of that Steve but I guess it would have an effect like a tuned pipe on reversion, interesting...
Anyone down flow-bench tests on a step like that?
