Eye of the Toiger
matty74's Avatar
Can I use manifolds 35/46mm on 40mm webers?
what is the performance impact?
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 09-22-2006, 01:01 PM
Eye of the Toiger
matty74's Avatar
bump
Old 09-22-2006, 01:53 PM
You betcha,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-22-2006, 03:14 PM
Super Moderator
cstreit's Avatar
THey will fit.
However I've not measured the performance impact. Certainly you'd get some turbulence transitioning from the carbs to the manifolds, I imagine this would manifest itself primarily under high RPMs.
You'd essentially have a "stall zone" in the air flow...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-22-2006, 03:23 PM
Works fine, and helps contain reversion when using race-type cams.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-22-2006, 03:29 PM
Super Moderator
cstreit's Avatar
Never thought of that Steve but I guess it would have an effect like a tuned pipe on reversion, interesting...
Anyone down flow-bench tests on a step like that?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 09-22-2006, 06:00 PM
