CIS injectors
73.5 CIS
how solid should the injectors be seated in the heads? some of the injectors installed on my engine move when wiggled at the lines connection to the injectors.... |
Mine 'feel' loose as well, but I have found no vacuum leaks so I am not worried.
Friction fit only, if they are leaking vacuum, pull them and install new o-rings.
Your situation is normal...
I just replaced all my injector seals/o-rings they feel "loose"
thanks for the info...
just paranoid.... had a leaking fuel line in the engine bay. injectors had been replaced by PO, some are more loose than others; car runs like a bat....... |
| All times are GMT -8. The time now is 07:46 AM. |
