Wayne's 101 projects says: On late-model cars, the horn pad simply snaps onto the wheel, and can be removed by pulling on it. Is an '87 a late model in this case? The picture in his book doesn't look like the wheel I have. I've removed the two plastic blanks in behind and feel like I'll break something if I pull to hard on the pad
This is my wheel
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
one of gods prototypes
remove the 2 plastic blanks behind the horn pad edges.....the grab each side and "pull", don't rip it like a gorrilla, just a quick firm tug.....then pop....it's off, unplug the horn wire and you're done.
Brought to you by Carl's Jr. |
Just Pull it, It is spring loaded. Thanks mark
1985 Targa Carrera 1972 914 2.5L four, side shift 1987 944 2005 Husqvarna CR125 1980 YZ125G |
OK, I'll give it a try.
TIA That pad is REALLY TIGHT ! I can't pull it off. Is there something I'm missing, besides stregth )Yep, strength is all that was missing It's off
Henri Owned for 21 years: '87 Carrera coupe Venetian blue Last edited by Hendog; 09-25-2006 at 08:38 PM.. |
Hey, remember this - "If it doesn't fit, force it. If it breaks, it needed replacing anyway."
![]() Just kidding. |
