89 911 Carrera Coup - randomly will not engage starter
I have a 1989 911 Carrera Coupe w/30k miles. It randomly will not start after turning the key; I will hear a click. However, 99% of the time when I recycle the key again it will start (rarely does it click twice). It will do this cold or hot.
My mechanic (w/nil Porsche experience) said he thought it was a solenoid. I called Pelican_Parts to order a solenoid, they said you can't buy just the solenoid, but it could be the "electric part of the starter", thus I purchase what they recommended. It appears to be an electrical plug
964-613-012-00-M100 Electrical Portion, Ignition Switch, 911/911 Turbo (1970-98), 944/968 All from 2/85, 928 (1978-95), 912E, 914-6
It looks like what's plugged in behind the key mechanism.
Can anyone offer any advice before I have my mechanic install this part; ie: if its more likely to be the starter or otherwise -- before I let him tear into it.
Thanks; any insight would be appreciated,
Elton
06 Touareg v8
04 Cayenne_S
89 911 Carrera Coupe SA Black
86 911 Turbo (sold)
84 911 Carrera Coupe (sold)
79 911 SC Targa (sold)
71 Ferrari 365 GT 2+2 (sold)
68 Rolls-Royce Corniche Convertible
62 Rolls-Royce Silver Cloud II Convertible (sold)
84 Rolls-Royce Silver Spike
86 Daimler DS420 Limousine
60 Cadillac Limousine
64 Mercedes Unimog
74 VW Thing
57 BMW Isetta
Old 09-23-2006, 06:51 PM
ruf-porsche's Avatar
starter solenoid or bad ground
You can sometime find them on Ebay
Old 09-23-2006, 06:58 PM
I'll have the gound checked first. If its the ground, where is this accessed; under the dash, in hood, etc.?
Assuming its not the ground, can I replace (purchase) just the solenoid, or must I get a new starter, as the PP rep implied?
Thanks!,
Elton
06 Touareg v8
04 Cayenne_S
86 911 Turbo (sold)
64 Mercedes Unimog
74 VW Thing
57 BMW Isetta
Old 09-23-2006, 07:04 PM
Ground strap between the engine/trans and the body underneath the car.
You can check the ground by connecting a set of jumper cables from the battery directly to the engine block, connect only the negative terminal.
If the starter engage without the usual click it probably the ground. If you still get the click its the starter solenoid, and the starter is a B!tch to remove even with a hoist.
go to ebay and do a search for Porsche solenoid.
Old 09-23-2006, 07:10 PM
Thanks!; really appreciate your help.
Elton
06 Touareg v8
04 Cayenne_S
86 911 Turbo (sold)
64 Mercedes Unimog
74 VW Thing
57 BMW Isetta
Old 09-23-2006, 07:27 PM
