Can I leave the evaporator blower functional w/o evaporator?
Will it still blow fresh air through the dash vents?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Tired Member
It will blow recirculated air from the cabin. I've got an evaporator, if you need one.
Glenn
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
I'm removing the AC. I find that the fresh air blower is insufficient on humid/rainy days. I thought that if I kept the evap. blower, I'd get more air circulation in the cockpit.
Tired Member
You'll get the circulation but without A/C, there will be nothing to dry the air. I find that running the A/C and heat together does the trick on those days when it is cool and humid.
Granted, rainy and humid where you are is pretty different than rainy and humid where I am. So.... results may vary. ![]() Glenn
