dw
Guest
Posts: n/a
Hood Emblem
Found a huge gash on my hood emblem the other day. Got a new OEM one today and tried to take the old one off. Can't seem to get a hex-nut socket around the old one's bolts, is there a special tool that's needed?
Thanks in advance
DW
89 Targa
Old 06-11-2000, 05:18 PM
rboylan
Guest
Posts: n/a
It's not threaded but it does screw on. Sounds crazy but true. Try a vice-grip with minimal pressure and manipulate a little before attempting to remove the nuts. Should do the trick.
Rich
Old 06-12-2000, 06:27 AM
dw
Guest
Posts: n/a
rboylan,
How do I get the vice grips into the small access holes??
DW
89 Targa
Old 06-12-2000, 08:48 AM
rboylan
Guest
Posts: n/a
Try the needle nose version. I'll do it tonight and let you know.
Rich
Old 06-12-2000, 10:55 AM
stormcrow
Guest
Posts: n/a
I think a 3/16 nut driver will do the job for you without any problem.
Regards
steve
Old 06-12-2000, 03:10 PM
GeorgeK
Guest
Posts: n/a
It's two 8 mm nuts. Be careful not to drop them in the doble wall area. Don't ask...
Old 06-13-2000, 01:17 PM
GeorgeK
Guest
Posts: n/a
dw
Guest
Posts: n/a
Yeah, I was thinking about that problem myself. Might have to put a little bit of tape around the socket to secure the nut.
DW
89 Targa
Old 06-13-2000, 06:31 PM
GeorgeK
Guest
Posts: n/a
What worked for the 2nd screw was putting a glob of grease on the socket to hold the screw.
Old 06-13-2000, 10:58 PM
