-   -   3.8 RSR fanbelt/pulley setup... (http://forums.pelicanparts.com/porsche-911-technical-forum/306208-3-8-rsr-fanbelt-pulley-setup.html)
Jeroen 09-25-2006 02:41 AM
A friend of mine has bought a RSR single belt setup for the 3.8 engine he's building
But is seems to be incomplete...
Does anyone here have pics or a scematic of these parts?
Just so we can figure out what is missing exactly
Thanks!
Bill Verburg 09-25-2006 04:49 AM
There are 2 different set ups.
Serpentine
RS
Assuming you are talking RS, these are the parts needed.
http://forums.pelicanparts.com/uploa...1159184887.jpg
http://forums.pelicanparts.com/uploa...1159184932.jpg
The single pulley is only applicable for 993 engines.
84toy 09-25-2006 06:42 AM
Bill, those look like Porsche parts or at least the fan hub. Is the pulley a Porsche item too? If yes, what is the diameter? I'm buildiing a 3.6 and was going to use the PMS setup.
Bill Verburg 09-25-2006 08:58 AM
Both are oem production Porsche RS parts.
The PMS set up uses a different setup w/ a serpintine belt, very expensive. Clewett has a similar system
rattlsnak 09-25-2006 09:27 AM
It cost me @$0.00 to build one myself. Went to a local welding company, they gave me a 4" alum solid rod 5 inches long.(scrap), measured it, cut it down on a lathe, and drilled 3 holes for the screws and one center hub. Worked perfectly, and is stll working 5 years later! (of course this was long before other people made kits, and I didnt know about the factory setup!)
Jeroen 10-08-2006 03:57 PM
he mentioned there was a spanner wheel included, so I guess it's the serpentine set up
mjshira 10-08-2006 04:07 PM
that sounds like maybe a clewett part? maybe patrick?
Craig 930 RS 10-08-2006 04:12 PM
Clewett - on a friend's 3.6:
http://forums.pelicanparts.com/uploa...1160349128.jpg
