Performing Compression Test
I've got my 2.7 engine removed from 1975 P car.
Can a compression test be carried out with the engine removed from the car? |
Yes you can...but it is always recommended to do it when the engine is warm if you want an exact reading result.
It would be better if oyu could swing a leakdown, I had nominal compression, however I had a 35% leak past the rings.
What I am concerned about is a damaged valve, the engine was running fine when removed but there was a slight knocking sound.
My guess was that a compression test would easily identify if I had a damaged valve. |
If you suspect a damaged valve, minimize engine rotations. I would perform a leakdown test at this point. Before testing, remove the valve covers and verify the suspected valve is not so bent it is stuck open (valve vs piston = bad).
If okay, manually rotate engine so test cylinder piston is at TDC, end of compression (careful), then do it. If you bent a valve, it'll be pretty obvious where the air leak is. Sherwood |
Ok
Thanks for the help all. |
| All times are GMT -8. The time now is 07:44 AM. |
