one of gods prototypes
replacing pot in dme
did my co2 adjust this weekend and noticed that the pot in my 85' carrera dme brain doesn't "indent" when turned to the next position, it does stop in position 1 though so i was able to adjust my mixture properly.
anyone have a part number for this indented potentiometer? i like having the option to switch it for cheaper gas if the need ever occurs. thanks
Brought to you by Carl's Jr. |
I searched my PET CD ROM catalog but they don't break the DME down to that level.
Henri '87 Carrera coupe: Venetian blue |
The fuel quality switch isn't a pot ... it is an eight-position octal [0-7] switch.
X700
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 09-26-2006 at 09:51 PM.. |
good info warren.
turns out that the switch works fine, where you insert the small screwdriver is all chewed up though which was hard to see with the dme mounted.....probably from the previous owner......or me....who really knows ![]() i'm planning a steveW chip this spring so it'll be replaced at that time ![]() thanks
