Counterclockwise?
Camber is great but ....
After noticing the outside of my front tires are far more worn than the inside I gave it more camber.
I just pushed the top of the shock tower until it stopped. No pressure. My gauge is showing approx. 3/8" difference from the bottom to the top of my rim. My castor stayed the same.
Should I be worried about damaging anything else that should be adjusted?
I don't think so but thought I would ask.
Anyone know what 3/8" on 16" Fuchs is in degrees?
Thanks in advance.
Rod
BTW: Whole lotta fun in the corners this morning
Rod
1986 Carrera
2001 996TT
Old 09-27-2006, 07:47 AM
gestalt1's Avatar
i just did a quick autocad drawing and the degrees works out to 1.34 degrees negative - this is good for a street driven car. i would not worry about wear on the inside edge at this camber setting. toe settings will have more wear on tires than camber. You should check the toe - it will change when the camber is changed.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 09-27-2006, 07:55 AM
Used Up User
imcarthur's Avatar
-1.301952673 degrees for 16" rims according to my calcs (elaborate spreadsheet formula I stole from somewhere on the net). Bear in mind, you want equal side to side & more on the rear.
Ian
'87 Carrera Cab
Old 09-27-2006, 08:07 AM
Don't forget the "edge" of 16" rims is more like 17" actual....edge-to-edge...
-Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-27-2006, 08:11 AM
Counterclockwise?
Thanks Guys.
The rims are 17" from where my "measuring tool" touches top to bottom of the rim.
Last time I checked I was around 1.5 on the rears and they are measuring around 1/2".
Visually the set up looks perfect.
I checked the toe before changing the camber and it was a hair in.
Would giving negative camber not bring the toe out and to 0 toe, which is what I want? It was too late last night to check.
Rod
1986 Carrera
2001 996TT
Old 09-27-2006, 09:19 AM
