Highfield's Avatar
Induction Options for 911T
I have just acquired a 1973 911T/E that is running Weber carbs.
On a previous post, they were split opinions on whether to return it to CIS, MFI or keep with the Webers.
Would appreciate thoughts on pros / cons of each.
Ian Highfield
1992 964 C2 Manual with RS Suspension etc.
1973 911T Narrow body Hot Rod with 2.7 Carrera engine and loads of period modsl - SOLD
1986 Carrera Coupe Sport with Stainless Silencer and SW Chip (256 fwbhp) - SOLD
Old 09-25-2006, 02:49 PM
Home of the Whopper
That's easy, whatever it came with originally. Make sure you have the right heads for it first.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 09-25-2006, 03:12 PM
Warren Hall Student
Bobboloo's Avatar
If the car is all original and has matching numbers then it will be worth more at re-sale time with the original type induction.
Is the car originally a 73.5 CIS T? If so are the Webers the only mod done to the motor? In otherwords were any changes made as to the cams or pistons?
If the rest of the motor is stock CIS then carbs don't do much in the way of increasing performance without additional mods. They just tend to burn more gas.
Give us some more info so we can give you better feedback.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 09-25-2006, 05:57 PM
Highfield's Avatar
Unfortunately until I can get hold of the previous owner and their records, I do not know if any other changes apart from webers and SSI have been done.
Is there a way to identify the heads ?
Ian Highfield
Old 09-25-2006, 11:33 PM
Difficult to measure valve sizes in an assembled engine, but you could access the intake/exhaust ports and measure. I believe 911T heads have 32mm ports. Compare port specs with other heads, then extrapolate the valve sizes available for the different heads.
You can determine cam timing by measuring valve lift with an indicator on the valve retainer.
Sherwood
Old 09-25-2006, 11:46 PM
