valerie
Guest
Posts: n/a
Carrera Chain Rattle
The chains rattle on my 87 on startup only. My guess is that it is related to a relaxing in the tensioners until oil pressure builds up.
Does anyone know if there is an O ring in the tensioner piston or if a check valve is used. In either event can the tensioners be opened and inspected or is the only option to change them out. A kind of low grade troubleshooting.
Ned Monaghan
Old 06-18-2000, 11:18 AM
Leland Pate
Guest
Posts: n/a
Ned, I have the pressure fed update on my SC and just a couple of weeks ago my right chain started making noise. I don't know what caused it but I now think that it goes away after the engine fully warms up. What could cause this? Anyone?
Leland Pate
___79 SC Targa
Old 06-18-2000, 02:56 PM
Early_S_Man
Guest
Posts: n/a
I don't really know what to tell you guys, because I haven't done any post-mortem examinations on failed pressure-fed tensioners!
All that I know is that Bruce Anderson says they can and do fail, but that the failure rate and database of incidents is still too sparse for causes to be certain, yet.
Warren Hall
1973 911S Targa
Old 06-18-2000, 07:13 PM
FRED/LI
Guest
Posts: n/a
Valerie; See the 'chain noise' post on this bbs from Leland, dated 6/12, last post 6/15 for a host of other ideas.
They do fail and I suspect that there will be more and more related posts.
Old 06-19-2000, 11:20 AM
