TWork's Avatar
Turbo Tie Rod Install
Iím trying to finish up the R&R the front suspension of my 911T project. Most recently, Iíve been installing a turbo tie rod kit. I thought Iíd snap a few pics along the way for those considering doing an install.
Because I had the struts out and control arms off, I just went ahead and pulled the cross member and steering rack. The Bentley has a very good exploded diagram. Itís really a matter of 4 bolts. You also have to disconnect the steer rack in the smugglerís box. I didnít have AC, so this was a pretty simple operation.
Once I had the rack out, I just put a pipe wrench on the old tie rod and it twisted right out. After I had it out, I put the washer in place and screwed the new tie rod in. The Bentley suggests doing a measurement of the old tie rod and making the new tie rod as close as possible in length.
The tie rod screws into the round flat piece of metal that the steering rack boot attaches to and then it screws into the actual steering rack. In order to preventing binding between that flat piece of metal when trying to screw the new tie rod into the rack, I had to remove the spring retainer that holds the boot onto the metal plate and screw the new tie rod into place. Once I had it torqued down, I then put the spring retainer back in place.
Here's an "exploded" view of the steering rack, cross member, etc:
Here's a pic showing the washer and the tie rod being screwed into the rack:
Moving the retaining spring out of the way:
Tightening things up. A vice was essential:
A comparison of new vs. old:
Hope some folks find it helpful.
T.
'73 911 T
Old 09-27-2006, 04:00 PM
JK-81SC's Avatar
Very nice write-up.
I did mine a couple weeks ago while it was in the car. It was a major pain trying to get the inner spring retainer on the boot, while it was in the car. If I had to do it over again, I'd do it your way.
Another benefit of taking the whole rack out is that you can get an accurate bolt-to-bolt measurement for the tie rod lengths, before the old parts are disassembled.
Jeff
1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift
1998 F-150 4x4 - Snow Time
1998 Yamaha WR400 - Mountain Ride
Old 09-27-2006, 04:30 PM
FenderGuy's Avatar
Are you getting alignment???
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 09-27-2006, 04:55 PM
TWork's Avatar
I'll definitely be getting an alignment when all is done. The car didn't run when I got it, so I have no idea how the alignment was prior to my mods.
'73 911 T
Old 09-27-2006, 05:00 PM
This is good information since I am about to replace thesteering rack on my 72 and add turbo tie rods.
Can you tell me if there is a difference in fitting the tie rods to a steering rack from a short wheel base car versus one from a long wheel base car.
Chris
72 TARGA . Sold 2009
70T Non-Sunroof Coupe.
Old 11-09-2006, 09:44 PM
MBEngineering's Avatar
HI T the steering rack boots need replacing with the turbo ones, which fit onto the rubber collars on the new steering shaft you have just fitted, otherwise the nice new ball-socket which is now open to the element's will not last long, the big washer is the lock-stop for the rack, and the large lock nut/boot holder you have re-fitted is not used, you may find if you put everything back as it is now the tracking will be towing in some what. The boot you require is 930 347 191 02 .
regards mike
Old 11-10-2006, 05:40 AM
Somatic Negative Optimist
Gunter's Avatar
TWork:
Did you correct the boot-issue brought up by Mike?
Pictures of the procedure with the right parts would be greatly appreciated.
Thanks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-13-2007, 08:02 AM
Confused
Nemesis
I have them on my '67 SWB - no problems, but a good idea to get Pelican's kit with the spacers and boots all included.
Although if you are fitting them to a 72 - isn't that a LWB car? Should be according to my information - although maybe I misread your plans
Regards
Guy
Squeaky brakes are safer....
2000 GT3 Clubsport, 1967 911 2.7 Track toy in progress
1983 Lamborghini Countach 5000S, 2009 VW Tuareg, 6 Bicycles - 3 Road, 3 Mountain
Old 01-14-2007, 09:35 AM
SP2 SP2 is offline
SP2's Avatar
T,
Yes, your new boots will cover the ball joint of your new tie rods. Congratulations, you make it look easy with everything out of the car. I did it with the rack in the car and it was much harder. Much! Don't get it aligned until you are sure you won't be doing anything to the a-arms (bushings, new torsion bars, ball joints) or won't be doing anything to the rear (bushings, torsion bars). If you have never had alignment and lowering to euro height, you are in for a surprise.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 01-14-2007, 09:48 AM
