kwm kwm is offline
dash repair kit
OK I admit it I played the sucker and bought one of these dashboard repair kits. I mean it looked professional enough. OK maybe it was me and not the kit.
Anyway, has anyone used one of these they are sold at most all auto parts stores. I had a very small 1/4 of an inch at best crack in my dash in that nook area where the pass. side meets drivers before the hump that goes over the gage cluster. The area I repaired is anything but unnoticeable.
As I read the instruction you were, for small cracks, to add hardening powder to the color matched little tubs then fill it in and finally hold a small swatch that matches the texture of your dash over the repair. Anyone used one of these?
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 09-27-2006, 05:07 AM
Patton's Avatar
Take it back if you haven't opened it. They are pure #$@&%$# junk.
Patton
No Porsche at the moment but give me 6 months and then......
Old 09-27-2006, 02:39 PM
Dash Repair
I think it's pretty much impossible to fix dash cracks. One thing you might try to keep it from spreading is to take your drill with a very small drill bit. Drill a hole at each end (if possible) of the crack. That might keep it from spreading - for how long, nobody knows. The circular hole dissipates the tension where the crack is propagating itself.
Good luck.
Marv Evans
'69 911E
Old 09-27-2006, 05:01 PM
ruf-porsche's Avatar
Re: Dash Repair
Originally posted by Evans, Marv
............. The circular hole dissipates the tension where the crack is propagating itself.
Good luck.
In Engineering terminology's we would call that the stress point.
Old 09-27-2006, 06:20 PM
kwm kwm is offline
thanks guys, I wish I had not used the kit already but I did. If anything it made it worse (looks-wise). The directions said to feather the compound out form the crack. To help it look better (or actually bring it back to where it was before I started) I am going to try to take a razor and lightly scrape the stuff up leading up to the crack.
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 09-28-2006, 05:10 AM
My PO tried that, it looked really bad, and then the dash started curling. I cut it smooth, well sorta, with a butcher knife and an electric knife, and put a black plastic dash cover on. It looked great. It really looked great. That cap was about $100. It was on for a year before I lucked out and got a recovered leather dash on eBay for really cheap. The plastic cap looked as good when I took it off as it did when I put it on.
Old 09-28-2006, 05:36 AM
kwm kwm is offline
$100 not bad. Do you know where you got it?
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 09-28-2006, 05:38 AM
I still have it. You can have it. Give me your shipping address.
Old 09-28-2006, 04:51 PM
