Early Car (Trunk) Fuel Tubing (w/pics)
Can someone please educate me?
![]() The large leg of the Y above comes from the top of the tank. ![]() The small leg (above) goes here: is this an overflow/drain? ![]() The large leg goes to this "module" (above) under the windshield. What are these for? I am assuming these are not: - the main fuel lines - vapor recovery (since I can see the charcoal cannister and it uses fiber hose) When I fill up with fuel I smell a lot of vapor and I'm trying to narrow down the source. The tubing in the photos above is rock hard BTW.
David 1972 911T/S MFI Survivor |
Anyone?
vapor recovery and venting lines - yours are bad and are dangerous
search on vapor + emissions + hose* for the numerous threads
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 09-27-2006 at 04:14 PM.. |
Thanks guys - but can anyone identify the part under the windshield witht he big and little hoses?
Item 2 in the above figure; it a vapor holding tank or bottle. |
be sure to read the info on what type hoses to use - ordinary PVC is a no-no
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Thanks Jim and Randy - any idea what that holding tank actually does?
Hi,
The under dash tank collects the fumes until they can be exhausted through the charcoal canister. The tank in the fender collects liquid to allow it to evaporate and tehn go to the charcoal canister. I just redid my hoses. figure on an afternoon of "fun". I did an Autocross this weekend and I was suprised at how much liquid was in the hoses at the end of the event. When I got home (20 minute drive) 95% of the liquid was gone.
Dan in Pasadena '76 911S Sahara Beige/Cork |
& brittle...
does NOT have to be liquid fuel -- vapor + spark from battery = !! and the vapor is harmful for you to breathe - mainly due to benzene
My hoses (the tubing in the pics above) are rock hard!
that's a bad sign; time to replace them
