Rocker Shaft Leaks
I recently finished rebuilding my engine on my 82 911 SC, my machinist polished and inspected the rocker shafts and I installed them at the factory spec ~13.2 ftlbs. Since several are leaking can I just tighten to a higher spec or do I need to remove and repolish etc?
3.4 Bigger is better
I torqued mine to 18ft lbs and have had no problems. The reason I did is that in another thread about this John Walker recommends the above torque. So yes I would go ahead and tighten them up. Do a search on this in the engine rebuild forum, there are numerous threads talking about this.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Bird. It's the word...
Twist 'em tighter. You can also consider adding RSR seals which were not used from factory, but were a racing option.
John Forcier Current: 68L 2.0 Hotrod - build underway |
Tighen them first and see what happens. If the leaks stop, great, if not, pull them out. It can be done with the motor in the car, not easy, but it can be done.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I had a similar problem after doing the guides on my Carrera.
First, I tightened the shaft and that reduced the drip rate. Since the leak was from #5 exhaust and was dripping on the SSI I could still smell it so better was not good enough. Next I put #5 on TDC, removed the assembly and cleaned and polished the rocker bore and the shaft. I reasssembled with the bolt in the other direction, checked my clearance which did not change and lived happily ever after. There was a little mysterious copper color transfer from the bushing to the shaft. Only visible, not feelable. Ant ideas on this color?
Ned NYNA 11 87 Carrera targa 98 BMW 528i 98 Volvo V70 |
Thanks for the advice, I will work on them this weekend and see if the leaks stop.
