I was freakin yankin in and out of traffic today.....awesome.
Just kidding....
Any feedback on magnecor wires? Will there be a noticeable difference in throttle response using these? Just curious. I'll be changing my engine and tranny mounts next week replacing them with the sport motor mounts. I called Pelican to find out the difference between the Meistersatz brand as compared to the freudenberg and response was that they were practically similar. $40 difference each. Any one use these?
Carl, |
I'm with Bill
I just installed Magnicore wires on my SC. It was a night and day diff. I must also add that my old wires were the origional ones. 24+years of service had left them in a poor condition. My comparrison might not be the best because of my situation but I would buy them again.
I also just replaced my mounts with the "sport mounts" I will go with the wevo's next time.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Virginia Rocks!
Re: I was freakin yankin in and out of traffic today.....awesome.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Monkey+Football
3 years ago, I went from stock to Magenecors, noticed a difference right away, but I'm like Rick, my stock were original to the car. a month ago I swapped out Magnecors for the Clewett ones our host sells, I noticed no difference between those two.
Save yourself the bucks.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. Last edited by Icemaster; 09-29-2006 at 05:26 PM.. |
As others have offered, you will only feel a dramatic difference if the old wires were leaking, cross firing or had excessive resistance. When compared to otherwise good wires, Magnacors (or any other wire) will provide zero difference. However, there is a discernible difference if the wires are red or other bright color.
Sherwood |
Rick, Are you not satisfied with the sport mounts? Not much difference from stock?
Carl, |
Super Moderator
They're red = Faster.
I love this place when the sarcasm is so thick you can cut it.
![]() All you yankers..........................
Diss Member
You can't get the fire in the engine to be "more burnt" then burnt. Either it lights off or it doesn't. Timing, swirl and squish are the only real modifiers to speed and completeness of combustion and wires can't change it. If you are missing even 1 in 50 times it will make a noticeable difference though. Putting new stock wires in would do the same thing.
That being said I have Magnecor 10mm wires on my car and I like them very much. The silicone hasn't discolored, shown wear, or degraded anywhere in the last couple years and they cost quite a bit less then the stock wires. I think the key to a good wire is quality materials that will give you a long life and proper installation with dielectric grease between the boots and wires, between the boots and cap, and between the boots and plugs. This should give you an installation that will nearly run under water. (unlike some stories that I have heard about how 911s are hard to run in wet conditions)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Zeke,
I didn't aim my sarcasm to be any thicker than normal. "However, there is a discernible difference if the wires are red or other bright color." ..... only meant there is a difference, and it's visually. By the way, my now dull, once brighter orange, stainless steel core wires have lived on my engine longer than my oldest offspring (18 years). I should take a peek at the light show in my darkened garage sometime though. Sherwood |
Hey, you better watch it....he called me a "Dork" for giving him a bad time about the yanking. "Too bad" that thread was closed.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
yankdork....
I once introduced myself at a job seminar as a yankee from Baton Rouge...
(in Louisiana a yankee means (or used to mean) a white guy that ws not French or Spanish...)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
im very happy yanking w/my racey red NOLOGY WIRES and COIL!
NOLOGY's test bed is the owners 930. wanking and yanking thats the life for me! |
Sultan of Sawzall
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
...in that case, you guys should go and try the "Magnicores". they're easily 2hp over the 'other ones'.
dave 1973,5 |
I'm with Bill
And yes I replaced all 4 before someone asks. Ok now Ya'll get back to your Yanking
1 Nomination for "Thread Title of the Year".
1980 911SC Targa 3.6L |
Monkey+Football
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
OK - back to the subject. How does one determine if the plug wires are original from the factory?
2011 Cayman Speed Yellow 1988 924S (Sold) 2000 Boxster S (Sold) 2006 Cayman S (Sold) 1990 964 C2 (Sold) 1978 911 SC (Sold) |
