Main and rod bearing - best source?
I need to buy main and rod bearings and am looking for advice on where and what to buy. I’ve read a bunch of posts about Glycol bearings being out of spec. Whatever I buy, I plan to measure them and compare them to my old bearings.
For main bearing set, host currently sells Gylcol. I’ve also found what are called Calico CT-1 at Patrick Motorsports. For rod bearings, I’ve found Gylcol and Automotive Associates here. LN Engineering sells Clevite and Patrick Motorsports sells the Calico CT-1. This is a stock rebuild. Thanks.
1986 Carrera coupe - black on black 1972 CB500/4 |
Go up the street to AA, works for me.
You’re generally local and being able to ask questions to a face really really helps build confidence. Bruce |
Thanks Bruce. They were very helpful.
