WydRyd's Avatar
Question Carrera Oil Tank?
Curious, how easy or hard is it to remove and replace the Carrera oil tank?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-29-2006, 05:01 PM
Jim Smolka's Avatar
It is very do able. Best to be prepaired to clean it and repaint the exterior. Since yours is a Turbo, it is easier than a NA Carrera
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 09-29-2006, 05:37 PM
WydRyd's Avatar
Thanks Jim. BTW, my car is actually a Carrera (aftermarket turbocharged).
Merv
'89 911 Turbo Cab
Old 09-29-2006, 05:56 PM
Jim Smolka's Avatar
It is a good idea to replace the funky plastic clear washers. Also, a good idea to replace the gasket for the oil level sender. The trick is to keep the dirt from going into the filler neck and oil filter hole when removing the tank. Duct tape works well here.
'81 SC 3.6 (Beast)
Old 09-29-2006, 06:04 PM
randywebb's Avatar
pressure wash the area first - it's nasty
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-29-2006, 06:43 PM
