-   -   Where can I find one (http://forums.pelicanparts.com/porsche-911-technical-forum/307204-where-can-i-find-one.html)
jetkona 09-30-2006 11:11 AM
Hi guys,
Well, the 88 911 Carrera I bought from Victory Motors turns out to have a locking lug set on it. Of course there is no wrench anywhere in the car so I need some help.
Below are a couple of close-ups of the nut. The best way to describe it is "round with three flats milled at even spacing. Anyone know who mfg's. these and where I might find a wrench? I've done some internet checking but no luck so far.
http://forums.pelicanparts.com/uploa...1159639850.jpg
http://forums.pelicanparts.com/uploa...1159639871.jpg
TRE Cup 09-30-2006 11:35 AM
the shape of the flats and their placement is fairly unique. Contacting Mcgard locks will do no good without a very accurate tracing of the shape, and then seeing if they respond with a few choices. Contact some wheel shops in your area. There is a lock removal kit, which consists of tapered hardened smooth sockets , that they can hammer onto the lock nut, then remove them. If that does not work, find a good TIG weldor that can spot face the end of the lock nut, weld on a bolt and back it off.
There is no way using a chisel ; you would damage the rims
good luck
Brother 09-30-2006 11:42 AM
I wonder if one of those gator - 1 size fits all sockets, with the pins inside would work.
TRE Cup 09-30-2006 11:49 AM
good idea to try if the outer dimension of the socket is not too large
Paul K 09-30-2006 11:56 AM
Contact the PO?
Good luck...
Paul.
