-   -   check engine light (http://forums.pelicanparts.com/porsche-911-technical-forum/30722-check-engine-light.html)
91C2wrencher 06-23-2000 11:42 AM
check engine light
Several times over the last week or so my "check engine light" came on. I checked the code and it appears to be the Knocksensor II fault. A couplo' questions, should i be concerned with this fault?, where on the engine is the knocksensorII?, what might cause it to come on rather randomly? any feedback would be welcomed. 1991 C2 Dave
mackgoo 06-23-2000 12:01 PM
Knock is not good, not knowing exactly what this does but guessing if it detects a knock it may adjust the timing to compensate. This probably should get imediate attention.
91C2wrencher 06-23-2000 12:26 PM
According to the service manual it says it does in fact retard the timing 6 deg. however i don't feel a change in performance. it would seem that 6 deg would be enough to feel?
