Clutch Cable Adjust: What's wrong?
I've been trying, and failing, to correctly adjust my clutch by the book. I have it to a place that feels good, but I don't understand what went wrong - any thoughts?
The car: 82 911SC
What I did:
-Disengaged the clutch cable at the tranny (using a hanging weight to keep the pedal up)
-set the distance between the set-screw and the little arm to 1.2mm
-engaged the clutch cable (still with the weight), adjusted the two nuts so the set-screw distance reduces to 1.0mm
What went wrong:
Once I pushed down on the clutch twice and rechecked the clearances there was no space between the set-screw and the little arm. I repeated the whole process twice, still to no avail.
Any ideas? I took it for a drive, and the clutch is perfectly usable.
Babak
PS I don't know if it makes a difference, but a couple days ago I found the clutch return spring on the little arm was missing and replaced it before these adjustment attempts.
Old 10-05-2006, 04:44 PM
Tired Member
DaddyGlenn's Avatar
I had the exact same thing happen to me!
What I found was the the bushings at the tranny were old and dry. There wasn't enough pull from the return spring or the pedal spring to get that last .2.
I rinsed the bushings with WD-40 then hit them with some lithium grease. then I worked the levers until my arm was sore. All that work got me to the point that I would release the clutch and a moment later the pedal would pop up just a tad more. After a month or two like that everything loosened up and it works perfectly now.
Changing the bushings is on my list of "to-dos" however.
Glenn
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 10-05-2006, 05:21 PM
