davis911s
Guest
Posts: n/a
Steering Column Bearing?
I've asked about this bearing before, My complete steering column moves a fair amount, I was told in a previous post how to fix it but can't find the part #, does anyone know it?
Shawn
77 911S
Old 06-25-2000, 08:51 AM
slarso
Guest
Posts: n/a
there are two ways:
You can buy (from Pelican?) a shim that slips under the existing bearings plastic race and makes the old bearing "work"
When mine went out I did not know of this quick fix. I bought the shaft bearing and started to dismantel the stearing assembely. After taking off the wheel, I noticed that there was about 1/4 inch inside the shaft that the bearing sits in, I simply slid the new bearing down the shaft and butted it up against the old shaft, it stickd out a bit but works just fine.
Good luck
Old 06-25-2000, 07:16 PM
