troy
Guest
Posts: n/a
Lubing Steering Rack
Can't find anything in the factory manual in reference to disassembly/reassembly of the steering rack. I Would like to clean and lube mine, is it a DIY deal, or are special tools required? Thanks, Tom Roy
Old 06-25-2000, 12:50 PM
Early_S_Man
Guest
Posts: n/a
Once you have it off the car, it is strictly a DIY job ... no big deal!
Warren Hall
1973 911S Targa
Old 06-25-2000, 02:57 PM
troy
Guest
Posts: n/a
Thanks Warren, looks easy enough to remove. Do I disconnect the column at the pinch collar/splined coupling? It doesn't look like I can get to the two bolts closer to the rack with the rack in the car. Thanks, Tom
Old 06-25-2000, 08:25 PM
