-   -   G50 from964 into 89Carrera which starter to use? (http://forums.pelicanparts.com/porsche-911-technical-forum/307745-g50-from964-into-89carrera-starter-use.html)
Jason917 10-03-2006 06:49 PM
Looking for advice solution to this problem..
G50/05 transmission from 92 964 C-2 mated to my 1989 Carrera with stock motronic and clutch system. The issue is the starter ring is larger in diameter, therefore I think it is grinding into the starter.
Anyone done this combination, if so is there a bolt on starter to use, or special starter-ring to buy?
The 964C2 starter would not work since I am using my stock Motronic, which needs the stock 89 flywheel for trigger.
Many thanks,
Jason917
